Networking issues after swapping to AMD
I've recently built a cheap gaming PC so i don't have to play games on my macbook anymore. But playing overwatch I am constantly at 100-300ms ping (up to 1000ms) on my macbook (on wifi) i get 30ms ping.
PC Specs
Ryzen 2600X
ASUS PRIME B450M-A
16 GB DDR4 Corsair Vengeance 3200Hz
GTX 1050Ti
120GB SSD
(Don't bash the specs I've built this to play one game and one game only and it plays at 200FPS fine)
What I've tried
  • Power line adaptors
  • 20m Ethernet lead
  • PCI-E Wifi Card
  • PCI-E Network card
  • Fresh install of windows
  • Download drivers from ASUS
  • Using different PSU
  • Tried ram at 2133MHz, 2933MHz and 3200MHz
https://linustechtips.com/topic/1244800-networking-issues-after-swapping-to-amd/
your ping is meassured ingame right?
are you connecting to the same server in both cases?
iam guessing when you ping something like google it isnt a problem?
is there alot of updates etc running in background that sucks up all your connection so the game data cant get through?
Quote
Yes
Quote
I honestly cant say but this has happened 10+ times
Quote
I get an average ping of 18ms to google
Quote
Not that i could see, i even upped my connection with my broadband provider to 200Mbps
22 minutes ago, CDay said:
Power line adaptors
In my experience, powerline has latencies that go all over the place.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
One easy way to find out whether the issue is on your side or the server, is to continuously ping Google while playing the game.
If you experience high latency ingame, but the ping to the google server is fine, then it's not an issue with your PC.
You can ping Google for longer periods by simply executing the following command in CMD
ping 8.8.8.8 -t
I had no issues with my Intel machine before i built this PC but ive brought new kitchen stuff recently so tried other methods as said above. I even used a 20m ethernet lead pluged in directly to my router.
ping 8.8.8.8 -t
Ill try that tonight when i get home
If you have connected directly to the Router using the patch cable, that is the fastest you are ever going to get.
Do a test with the patch cable to the router and then the Wifi/Powerline. Powerline has to be directly connected to the wall and not thru the power strip. Both the devices have to be on the same Electrical circuit.
If your ping 8.8.8.8 -t results are the same on Patch cable/wifi/powerline ( Wifi/Powerline may be a bit slow), then there is nothing wrong with the Network.
It could just be the Gaming server you are connecting to as it may have a lag.
One thing you can try to do is uninstall the network card from Device manager, and try the Auto reinstall, RC: Click on Search the internet.. Option and see if there is a difference.
The B450 Mb has known to be a problematic MB, although it is very popular among the builders, but it has documented bunch of issues as well.. just search this forum for B450 and you will see.
17 hours ago, CDay said:
Yes
sounds like a software issue or you are logging on to australian region on new computer and eu on old while living in the EU :)
are you copying the game from directory or are you making a fresh install of the game?
with all the steps you have tried i would suspect software, and i must admit you have tried the things i would normally suspect. so iam drawing a blank.
