so i just got a bunch of new hardware, my current rig parts:
mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130661
cpu:http://www.newegg.com/Product/Product.aspx?Item=N82E16819113348
ram:http://www.newegg.com/Product/Product.aspx?Item=N82E16820231720
gpu: ati x1950 old as crap (but should fit my needs)
ssd:http://www.newegg.com/Product/Product.aspx?Item=N82E16820211596&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-
Now i just installed windows 8 and all the drivers but the gpu driver, the driver that supports my gpu is a windows 7 or lower driver, however i dont think that matters so i downloaded it anyway and when i try to install the driver it tells me everything is up to date, after which windows notifies me that there is a problem with my graphics card and then when checking the device manager it shows that there is one driver but it is not for the x1950 and i know its not properly installed because diablo 3 Starcraft 2 and any other game i launch only plays at 1.2 - 2 fps.
i know i need a new gpu however there is no chance that i can get one in the next mounth or more so im stuck with it for a bit and it has in the past played d3 and sc2 at 35ish fps with worse system stats.
anyone know what the problem is? all and any help is welcome, I've been trouble shooting things for 2 weeks now and i just want to play a d3... Thanks!
CPU: AMD 760k @4ghz | Motherboard: MSI fm2-a55-e33 | RAM: G. skill 4gb @1833 | GPU: AMD HD 7850 | Case: Nzxt 210 Tempest (with glass window mod) | Storage: Adata 128gb ssd | PSU: Raidmax rx-530ss | Display: 720p crap | Cooling: CoolerMaster sickleflow 120 green x4 | Keyboard: crap | Mouse: Razer diamondback | Sound: logitech 2.1 speakers | Operating System: Windows 7 Ult | Battle.net: Voldras #1712
https://linustechtips.com/topic/124458-drivers-help/
You may not have a choice. There's no guarantee that really old hardware will be supported on new OS's. Either upgrade your graphics card, or go back to Windows 7. Since you didn't get an APU, you have no onboard graphics.
Did you choose the correct version of the driver? 32/64bit?
Edited by JohnnyGrey
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/124458-drivers-help/#findComment-1655581
Did you choose the correct version of the drive? 32/64bit?
yeah, 64 bit.... your probably right about upgrading...
https://linustechtips.com/topic/124458-drivers-help/#findComment-1655591
I had the same problem with one of my old laptops. There was some graphics problem when I installed Windows 8 that prevented me to play anything on it. There are some weird incompatibility issues sometimes.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/124458-drivers-help/#findComment-1656414
Older AMD/Nvidia cards usually have a LEGACY driver, as most older cards will not be seen/compatible with new drivers.
No doubt the older x1950 will not be seen with current drivers.
Pretty sure you need to install WhateverOS version/32 or 64bit ...............of the 10.2 Catalyst Drivers.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/124458-drivers-help/#findComment-1656438
