That is an adapter cable, most likely for a laptop's smaller mini display port connector. It can only be used one way. If you have 2 devices that need a normal HDMI port, look for a HDMI to HDMI cable, which most of them actually are. The cable you have selected here would be called an adapter because it connects different types of connectors.
https://linustechtips.com/topic/1243780-displayport-cable/#findComment-13996668
Monitor came with the same cable but it's too short. So I searched for the same but longer.
I have tested the short one and it works fine.
I have plugged the normal displayport on gpu and the mini on monitor.
https://linustechtips.com/topic/1243780-displayport-cable/#findComment-13996683
