help HELP me my storage problem
Solved by SupaKomputa,
7 minutes ago, Rocky6 said:omg that kinda worked but not fully i can see my rest of 687gb partition(RAW)
its fully free . idk waht to do next to show up in file explorer. pls tell me wt to do next
There you go, tell me how many partition there?
I assume some smaller partitions are for windows only.
You can extend the C partition, make it bigger as long as there's no partition after that.
You need to use third party partition programs, like easeus partition free.
When you open the program, right click C and click edit.
Then you slide the back position to the max allowed.
Hit apply, you will need to reboot to finish the process.
