16 minutes ago, natethegreat63 said:
usa and 1500is what i want to spent i want intel cause its better for vid editing and i want to future proof a bit and have power when i start 4k editing
welcome to the forum
remember to quote or mention the person you're replying so that they'll receive a notification
@lexusgamer05
does your workflow benefit from NVENC/CUDA?
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1243455-first-build/#findComment-13994424
15 minutes ago, natethegreat63 said:
@Moonzy its just for vid editng for youtube im ok it the build is over kill i just want it to work and plus work when i start doing vid in 4k
it looks ok though why 9700k instead of 10700k?
not familiar with video editing workflow enough to be able to give further advice on it
check out this subforum
https://linustechtips.com/main/forum/18-new-builds-and-planning/
https://linustechtips.com/topic/1243455-first-build/#findComment-13994454
On 9/6/2020 at 8:12 AM, natethegreat63 said:
i am building my first pc to do youtube and maybe stream but right now are vids are just in 1080p soon it will be in 4k is this build ok for that am i missing anything
Idk about the rest but you should buy barracuda 1tb it has 7200rpm it will be bit faster than your current hdd
https://linustechtips.com/topic/1243455-first-build/#findComment-13997824
