Hey guys, i was just wondering what kind of temperature the Intel 3770k would start degrading over time. Because i am getting around high 60's to mid 70's degrees when i am running prime95. But around 50 degrees when gaming, etc.
Thanks
MSI R9 290 Gaming | MSI Z77 MPower Big Bang | XFX Pro 750W Black Edition | i7-3770k @ 4.5GHz | Corsair H100i | GSkill Ripjaw 2x8Gb | NZXT Phantom 410 Gunmetal | OCZ 128 Gb Vertex 4 | Samsung 250Gb 840 EVO | 1&2 Tb Seagate Barracuda | Logitech G510 | Logitech G700 | Logitech G35 | 3 x LG E2442V
-it24-
https://linustechtips.com/topic/12430-cpu-temperature/
umm maybe your thermal compound wasnt put on well is it the stock cooler? and have you overclocked?
Rig: i5 3570k clocked at 4.4ghz stable/gainward stock gtx 670/ 256gb ocz vertex 3/ 2tb wd green/ zalman z11/ samsung 24x blueray reader/ benq 2411t 120hz gaming monitor
https://linustechtips.com/topic/12430-cpu-temperature/#findComment-132273
That's perfectly fine. :)
Tcase is 67.4C, but TjMax is usually 100C <- Max CPU temp. I wouldn't mind it if it's not over 85C when running full load after 1h. Is that your temps when overclocked freq? Or with stock on stock cooler?
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/12430-cpu-temperature/#findComment-132291
Those are good temps imo. If you want a better cooler, get a Hyper 212 Evo.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/12430-cpu-temperature/#findComment-132324
Thanks guys, I have an h100i with a cpu overclocked to 4.5GHz
-it24-
https://linustechtips.com/topic/12430-cpu-temperature/#findComment-132327
Temperatures are fine!
| CPU: INTEL i5 6600k @ 4.6Ghz @ 1.328v | Motherboard: ASUS Z170-AR | Ram: G.SKILL 2x8GB 2400Mhz | CPU Cooler : Corsair H100i V2
| GPU: GIGABYTE GTX980Ti G1 GAMING | SSD: SAMSUNG 840 EVO 250GB  Storage: WD 1TB GREEN | OS: Windows 10 Pro 64bit | PSU: FSP 650W AURUM S |
<<<<< BLK-Phant0m >>>>>
https://linustechtips.com/topic/12430-cpu-temperature/#findComment-133676
Mid 70's is fine, you don't have to worry until it does to mid 80's in prime95, and 50 in game is good
[THE TITAN]
CASECorsair C70 (BLACK+RED Leds) | CPU:  i7 3930k | CPU COOLER: Corsair H100i | MOTHERBOARDASUS Rampage IV Formula | RAM: Corsair Vengeance 16GB | SSD: SAMSUNG 840PRO (512GB) |
HDD: Western Digital Black (2TB)+(2TB) GPUGTX TITAN X2 IN SLI | PSU: Corsair AX1200i | SOUND CARD: Xonar Phoebus | MONITORS: ASUS PB278Q X3 IN NVIDIA Surround |
https://linustechtips.com/topic/12430-cpu-temperature/#findComment-134699
