Hey everyone, i just got myself a Lenovo duet chromebook and there are plenty tutorials out there for getting steam running but now i am out of solutions.
First some Data:
Operating System: Version 85.0.4183.84 (Offizieller Build) (32-Bit)
Linux Beta and GPU accl. Enabled
So i managed to download the steam install File from the official Website. After launching the .deb, following error get's displayed: 'you are Missing the following 32-bit libraries, and Steam May Not Run: libc.so.6'
i already tried to fix this by using the console, sadly no recommended commands worked Out for me.
Any help would be appriciated!
https://linustechtips.com/topic/1242990-installing-steam-on-chromeos-help/
10 minutes ago, Kanna said:
Wait that is possible?
Yes, I believe steam is supposed to be coming as a native app at some point. In the meantime you can install the Linux version.
https://www.pcgamer.com/steam-is-coming-to-googles-chrome-os/
You probably need to add i386 libraries. For Linux Beta on ChromeOS follow this, https://wiki.debian.org/Steam
Good point, already tried something similar with the i386.
Also i just looked up the debian website, but i have no idea how to handle linux or how programming works :( i don't get what do to until someone gives me a step-by-step.
this is what i already tried:
sudo apt update
sudo apt upgrade
after that:
1) sudo apt install libc6-i386
2) sudo dpkg --add-architecture i386
3) sudo apt-get update
4) sudo apt-get install libgl1-mesa-dri:i386 libgl1-mesa-glx:i386 libc6:i386
After smashing the first command in, this appears:
"~$ sudo apt install libc6-i386
Reading package lists... Done
Building dependency tree Reading state information... Done
E: Unable to locate package libc6-i386"
I don't get it :(
