75w is the standard value for PCIe slots, but prebuilt may have BIOS that only supplies up to 25w. That's why prebuilts are bad for modding.
Desktop benching:
https://linustechtips.com/topic/1242917-i-need-help/#findComment-13990360
1 minute ago, Ahsan Ghauri said:
How to check it?
searching in the internet or test it out yourself. Dont expect customer service team of Acer to answer such questions
Desktop benching:
https://linustechtips.com/topic/1242917-i-need-help/#findComment-13990373
11 minutes ago, Ahsan Ghauri said:
How can i test myself?
a card that pulls over 25w down the PCIe slot
Desktop benching:
https://linustechtips.com/topic/1242917-i-need-help/#findComment-13990435
31 minutes ago, Ahsan Ghauri said:
What will happen if it don't provide enough power?
the card will refuse to run
15 minutes ago, Ahsan Ghauri said:
Yes its sufficient
you mean the one that comes with the system? The board clearly has proprietary power connectors which means a normal ATX PSU may not power it properly, so you cant simply swap the original one out
Desktop benching:
https://linustechtips.com/topic/1242917-i-need-help/#findComment-13991400
13 minutes ago, Ahsan Ghauri said:
If i use 24 pin to 12 pin adapter?
idk. Prebuilt systems dont have to follow any standard and quite often, they do not.
Desktop benching:
https://linustechtips.com/topic/1242917-i-need-help/#findComment-13991422
41 minutes ago, Ahsan Ghauri said:
Hmm it means we don't know if the 24 pin to 12 pin adapter and pci-e slot would work until we try?
There's a difference between the two tho, PCIe slot wont cause danger but the adapter could
Desktop benching:
https://linustechtips.com/topic/1242917-i-need-help/#findComment-13991512
15 hours ago, Ahsan Ghauri said:
Yes its sufficient
I didn't ask if it was sufficient.  I asked if it was correct.
Ok.  So you're planning on using an adapter with an upgraded PSU.
Look... I don't know why you're being so vague.
Do you have the board already?  Do you have the graphics card already?  Do you have the adapter already?  Does the board work with the adapter and no graphics card?
Are we trying to actually solve a problem here or are you just slapping together speculation that this combination may or may not work.
https://linustechtips.com/topic/1242917-i-need-help/#findComment-13993181
I already have board, gpu, upgraded psu and adapter but i don't know if i connect them something will go boom
https://linustechtips.com/topic/1242917-i-need-help/#findComment-13993197
