Help me Choose between the Two
Solved by Fasauceome,
42 minutes ago, epicomark said:That's as close as I can get. That's literally the price. I can change the case btw I just can't find one same as the DeepCool
If you reduce cost with a cheap case and some DDR4 3000, you could hopefully make it fit in budget. You can also check out other B450 boards, since you said this was a local shop, and you can see which ones have the "ryzen 3000 series ready" badge on them, or ask the ship owner to update the BIOS. You might be able to find a cheaper board like a B450M DS3H or S2H.
