5 minutes ago, Flawizz said:
need psu experts to figure out which one of the following 3 psu's i should choose, need for 3080/3700x/16gb
All are excellent units. Pick whichever
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13986938
get the fully modular one, so much nicer to build with
SPEC LIST:
  • CPU: AMD Ryzen 9 5950X w/ NZXT Kraken Z73 360mm Liquid Cooler
  • GPU: NVIDIA RTX 3090 FE
  • RAM: Corsair Vengeance LPX 32GB (4 x 8GB) 5000MHz CL18
  • Motherboard: MSI MEG X570 Godlike
  • SSD: Samsung 980 Pro PCIe 4.0 1TB (x3)
  • PSU: Corsair AX1600i
  • Case: NZXT H710
  • Monitor: Alienware AW2521H 25inch 360Hz 1ms
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13986943
1 minute ago, Alex Ushigome said:
The cooler master since it's cheaper. Both the be quiet and Cooler Master are B Tier, can't find anything on the TX. How much does an RM650x cost?
120€, but i dont think 650 would do for a 3080, even if it does, might use some headroom incase ryzen 4000 drops with some nice performance increases.
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13986947
Dont bother if its 20 euro more. If you want to compare PSUs use this list
PC
Ryzen 5 2600 Stock
Peripherals
LG 24MK400H
Logitech Z150
Phone
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13986955
all 3 will be great, all have 100,000h estimated time between failures, all have high quality caps and chokes (most likely from the same factory), all have decent warranties, it really comes down to company preference.
beQuiet is my choice, 2x 12v rails is a "nice to have" however unnecessary in most high end psus like these.
The best gaming PC is the PC you like to game on, how you like to game on it
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13986967
2x 12v rails sounds like something really good, il have a look at whatever i can get from A tier, gimme a sec :)
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13986972
The BeQuiet and Corsair are both A tier I believe. The corsair one is the "TXM 2017 gold" I believe, unless the V2 is a different model
PC
Ryzen 5 2600 Stock
Peripherals
LG 24MK400H
Logitech Z150
Phone
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13986985
Just now, Flawizz said:
yeah i think i will go with the be quiet! Pure Power 11 700W CM psu
Good choice :)
PC
Ryzen 5 2600 Stock
Peripherals
LG 24MK400H
Logitech Z150
Phone
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13986997
@marmour The Pure Power 11 is Tier B with the Coolermaster MWE Gold.
@Flawizz The Corsair TXM would've been a better choice
For those blind, the TXM is Tier A
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13987111
I mistook the straight power for the pure power, my bad. Its still a decent unit though.
I did point out the TXM anyway, and yes it is the best choice
PC
Ryzen 5 2600 Stock
Peripherals
LG 24MK400H
Logitech Z150
Phone
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13987142
Oh I know, should've been more clear that the only part you were wrong was that the Pure Power 11 was Tier A when it was Tier B.
MAIN PC:
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13987211
oh right, but its single rail, i've heard bad stuff about single rail, the pure power 11 however has 2 rails as far as i've heard, did you take the rails into consideration when making your decision? thanks in advance!
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13990036
there’s no effective difference in safety between single-rail and multi-rail PSUs. It's more of an added protection since if one rail fails, the other still works. I would only factor in multi-rail if you were doing a multi-GPU setup in any case.
MAIN PC:
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13990309
I can actually make a real difference in the high wattage units.... ;)
Take mine as an example, HX 850... In multi rail mode it's 40 amps per rail, 7x 12V+ rails, or 480W MAX before it would shut down if something happened. In single rail mode that would be 70.8 amps or 850W that could do some real damage... Worst case....
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13990344
Take mine as an example, HX 850... In multi rail mode it's 40 amps per rail, or 480W MAX before it would shut down if something happened. In single rail mode that would be 70.8 amps or 850W that could do some real damage... Worst case....
Which is why it's a "nice to have" protection for most people. It's not a end-all-be-all when choosing a PSU.
MAIN PC:
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13990363
Never said it was.... ;)
It's added protection and more relevant for the higher wattage units.
Mine has 7X 12V+ rails so it breaks things up nicely in Multi rail mode.
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13990368
if the rails dont matter (as much as the tier), and the txm is A tier and the pure power 11 is b  tier, what makes txm worthy of A and pure11 not? i have no clue. thats probably gonna be my deciding factor if it is a very valid reason in tier difference. thanks in advance!
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13990374
Build quality, mostly. That and Corsair has a 7 year warranty vs 5 year from Be Quiet!. Also the TXM has better performance according to Aris
MAIN PC:
https://linustechtips.com/topic/1242501-help-choosing-psu/#findComment-13990464
