Audio switcher / router?
On 9/4/2020 at 6:33 AM, dalekphalm said:You don’t need to spend $500 to do this “digitally”.
Decent 4x4 Audio Interfaces can be had for under $400. You can get mixers w/USB for even cheaper (though usually an audio interface has better pre-amps).
I agree, the digital version is costly and can potentially add additional load to your CPU. Although DAC's are also expensive but are great if you want high quality audio, although most are built for Music Production/Audio engineering and the cost is mostly for the mic pre-amps and the overall build quality. With a DAC you will also need to spend more on professional audio adapter cables/adapters, as they only use the twin XLR or 1/4" jacks. This will add to the cost if you really need to use 3.5mm jacks.
Perhaps try something like the link below first, as it cheap and may just do the trick. But shop around to see what is out there. Search "3.5mm audio mixer" and see what fits your needs best.
https://www.amazon.com/MIXER-Bluetooth-Input-Audio-Output/dp/B0721SBHVD
With the mixer in the link, it seems to have Bluetooth and enough 3.5mm inputs, but you may need an audio splitter cable on the output for your plans. They are also very cheap on amazon.
Hope this helps :)
Throg
