pfSense assigning physical (LAN) IP's instead of VLAN10 interface
Solved by Lurick,
Why is VLAN 10 your native VLAN on the trunk? Change the native VLAN to 1 (or anything but the VLANs you want to stay tagged) and try because I'm pretty sure that is dropping the vlan tag for anything with a vlan 10 tag coming in and it's getting to the other side untagged on the pfSense side.
Featured Topics
Dedayog ·
mbecker ·
Posted in Peripherals1 -
Prajnaanicca ·
Posted in CPUs, Motherboards, and Memory2 -
2
3
2
ZGruk ·
Posted in New Builds and Planning2
