Need to upgrade my PC setups audio
Ratchet7989
Right now my monitor is hooked up through AUX to an old old iHome sound bar and its really starting to show its age. When building my PC this year i didn't really look into audio as much as i should have and am not really sure what is good or what i want (honestly feel like anything would be better). Any suggestions and tips would be greatly appreciated. thank you :)
"I'M ready to go, I'M already wet."
-Linus
actually its not even an iHome its an iLive whoever they are lmao
-Linus
1 minute ago, rice guru said:
whats your budget and usecase? if for music what genres do you listen to?
This will be for my everyday use PC so it'll primarily be doing game audio. As far as music goes I listen to just about all but country a lot of hard/punk rock and EDM lately though.
I'm unsure of even a budget but for the sake of a number maybe around $250? (USD)
My experience in audio has only ever been some car audio, home audio is something i'm just now getting into so i apologize if i don't have a lot of information to go on.
-Linus
do you want speakers or headphones?
Speakers
-Linus
Speakers
ah ok so for $250 you would be looking at the budget side of things. there are definitely some ways to go you can get some decent active speakers for $250 or some $150 speakers paired with a $100 speaker amp like I do
Sounds good do you have any suggestions?
-Linus
for gaming I persoonally reccomendd headphones but a nice set of nearfields postioned optimally will do pretty decently in gaming.
For active speakers some I would look into are the iLoud Microugly but can get ll0oud and pretty great sounding, Edifier S350db,JBL306P
Passive speakers need an amp to drive thenm I personally use a topping PA3 @80Wper channel it should be able to drive most bookshelf speakers at this price range  to a  deafening level, I use a micca Rb42 a small set of speakers with a V shaped sound signature. for their small size ,tthey have a impressive amount of bass and treble is a little booste, other speakers to look at are Jamo s801 , sony ssCS5
@Derkoli is our resident speaker guy though so he might have more ideas.
Passive speakers need an amp to drive thenm I personally use a topping PA3 @80Wper channel it should be able to drive most bookshelf speakers at this price range  to a  deafening level, I use a micca Rb42 a small set of speakers with a V shaped sound signature for their small size they have a impressive amount of bass and treble, other speakers to look at are Jamo s801 , sony ssCS5
I will certainly look into these things, thank you. :)
-Linus
For that sort of price range, I would look at a pair of JBL 305P MkII with an interface to act as a DAC/Pre-amp.
A Behringer UMC22 would be ideal to feed them. I've ran a pair of 308P MkII off this interface before, and it sounds pretty damn good for the price.
2 of these (one per channel):
https://www.amazon.com/TISINO-Balanced-Quarter-Stereo-Interconnect/dp/B083R4CDT2/ref=sr_1_8?dchild=1&keywords=trs+to+xlr&qid=1599060550&sr=8-8
2 of these (they come singles so you can make a 5/7 channel system up):
https://www.amazon.com/JBL-Professional-Next-Generation-Powered-305PMKII/dp/B077N2GQXC/ref=sr_1_2?dchild=1&keywords=305p+MkII&qid=1599060626&sr=8-2
The 305p's do actually measure quite well:
https://www.audiosciencereview.com/forum/index.php?threads/jbl-305p-mkii-and-control-1-pro-monitors-review.10811/
LTT's Resident Porsche fanboy and nutjob Audiophile.
Main speaker setup is now;
Mini DSP SHD Studio -> 2x Mola Mola Tambaqui DAC's (fed by AES/EBU, one feeds the left sub and main, the other feeds the right side) -> 2x Neumann KH420 + 2x Neumann KH870
(Having a totally seperate DAC for each channel is game changing for sound quality)
I'd look at a standalone set of active speakers like the Steljes NS3s as a fit and forget option.
Failing that if you want something a bit more iimpressive I'd probably look to a smaller passive desktop/bookshelf like the Q Acoustic 2010i or 3010i depending on available space and pair it with a £100 Class D amplifier. I had some £250 AudioEngine actives and replaced them with a pair of 2010is and a Sabaj A4 and the latter setup is much better.
[ P R O J E C T _ M E L L I F E R A ]
[ 5900X @4.7GHz PBO2 | X570S Aorus Pro | 32GB GSkill Trident Z 3600MHz CL16 | EK-Quantum Reflection ]
[ ASUS RTX4080 TUF OC @3000MHz | O11D-XL | HardwareLabs GTS and GTX 360mm | XSPC D5 SATA ]
[ TechN / Phanteks G40 Blocks | Corsair AX750 | ROG Swift PG279Q | Q-Acoustics 2010i | Sabaj A4 ]
P R O J E C T | S A N D W A S P
6900K | RTX2080 | 32GB DDR4-3000 | Custom Loop
Gotta say, those things would make for quite an impressive part of my set up. thank you for the recommendations
-Linus
They are a great little speaker. Measure well, balanced inputs, DSP/EQ, look pretty good and obviously they're JBL so the speaker is torture tested for 100 hours before you buy it, so it's gonna last a fair old while.
