Comp doesnt turn on, was wondering if it was insufficient power for the build?
By
Umm_ya
in Power Supplies
in Power Supplies
Solved by H6NS,
10 minutes ago, bellabichon said:By doesn't turn on, you mean "I hit the power button and it didn't work", right? Have you tried manually bridging the power pins on the motherboard?
Also, he should check the front panel IO on mobo if the power button in correctly connected.
Featured Topics
T3mpest ·
Posted in Troubleshooting0 -
stevenFM13 ·
Posted in Programming0 -
vanpuffelen ·
Posted in CPUs, Motherboards, and Memory6 -
2
7
