Hi i'm wondering if my current power supply is enough for the new rtx 3080 card. Switching from gtx 1080 founders to 3080 their power consumption on nvidia website is 180w for 1080 and 320w for 3080,
so is my power supply ok or not, i think it is but i would like to make sure, it's almost double in consumption.  I m not getting the card at launch a little after but i would like to know so i can prepare. Thanks
CPU: AMD Ryzen 9 3950X
GPU: Palit NVIDIA GeForce GTX 1080 8GB Founders Edition
RAM: G.Skill Tident Z Neo 32GB DDR4 32GTZN 3600 CL18 (2x16GB)
STORAGE: SAMSUNG 970 EVO Plus NVMe M.2, 500GB 2 X - Samsung SSD 860 QVO 1TB
COOLING: ARCTIC Liquid Freezer II 280
Power Supply: Corsair RM Series RM750 80+ Gold (modular) 2019 750 Watt
https://linustechtips.com/topic/1241507-help-powersupply/
750 watts is quite a lot, the 3950X consumes around 150 watts, and the rest of your system is under 100 watts. so that makes roughly 600 watts you're using, if we're being generous.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1241507-help-powersupply/#findComment-13979119
According to the NVIDIA official website, the recommended PSU for RTX 3080 in 750 W, thus you should be fine.
CPU: Intel Core i7 8086K, Delidded with Der8auer Custom Nickel-Copper IHS and Coollaboratory Liquid Ultra CPU Cooling: Scythe Ninja 5 with Thermal Grizzly Kryonaut Thermal Paste Motherboard: ASRock Z370 Taichi RAM: 2x16GB Kingston Predator DDR4 3200 MHz 15-17-17-36 GPU: Gainward RTX 2080 Phoenix GS with Raijintek Morpheus II Core Black Heatpipe VGA Cooler, Thermal Grizzly Kryonaut Thermal Paste and 2x Scythe Kaze Flex PWM 120mm fans Case: SilentiumPC Regnum RG4T Pure Black TG Storage: Samsung 960 EVO 250GB, Samsung 970 EVO 500GB, Seagate ST4000DM 4TB HDD, Toshiba HDWD240 4TB HDD PSU: SilentiumPC Supremo FM2 Gold 750W Case Cooling: 6x Scythe Kaze Flex PWM 120mm fans Keyboard: Corsair Strafe Mechanical Keyboard Mouse: Trust GXT845 Tural Display: Sharp LC-50LD265E Operating System: Windows 10
https://linustechtips.com/topic/1241507-help-powersupply/#findComment-13979130
Yes, it will be fine per NVIDIA's PSU recommendation for the RTX 3080 is 750W.
That's for the reference cards though, the partner cards could be more depending on the model.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
https://linustechtips.com/topic/1241507-help-powersupply/#findComment-13979391
