hibernate PC startup issue
Solved by SupaKomputa,
post code 40 means that it wakes up from hibernation.
after waking up, the pc will try to move the data from the hdd to the memory.
if it fails, it will try to reboot and resume with normal mode.
you probably have a problem with memory management.
check all of your memory slots, clean the sticks and slots with contact cleaner.
test each memory modules with Memtest86, make sure no error.
check the ssd space, ensure you have enough space for hyberfile.sys (should be 32gb or more).
run check disk on all drive, repair if you have any problems.
replug all sata connections properly.
open advance system settings > perfomance make sure you run pagefiles / virtual memory only on SSD not HDD.
