Corsair CX550 (grey) for 24/7 operation
Ac01
Hello,
Is the PSU suitable to run 24/7 in a hot environment, with a bit frequent gaming. PC parts may include a hexa core cpu & a Gtx 1050 ti.
how hot is "hot"? 30c ambient?
some PSU are rated for 30c, if you're looking for a PSU for hot climate, look for units that are rated for 40-50c
-sigh- feeling like I'm being too negative lately
30-35° Celsius  ambient temperature
according to this
it is rated to output its full capacity at 40c
and given your rig isnt too power hungry (modern 6 core + 1050ti  ~= 200W), it should be fine
10 hours ago, Ac01 said:
30-35° Celsius
Yea it should be fine.
Phone: Pixel 3a (Purple-ish).
Build Log:
according to this
The main concern is if it is capable to run mostly 24/7 for years.
Alright, thanks for your support.
