ok so I dropped my blue yeti and now the mic mesh is just deformed. luckily the audio isnt messed up but i tried to take off the mic mesh but just couldnt, I tried watching videos on people taking it off but all ive seen so far are asmr videos or taking everything apart, so is there a way to just take the mic mesh off without messing other things up?
https://linustechtips.com/topic/1240378-deformed-mic-mesh/
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1240378-deformed-mic-mesh/#findComment-13970634
6 hours ago, Ahoy Hoy said:
Tip of the trade.
Take the mesh off most microphones the mesh is screwed on.
Use the handle of a screw drive to press the mesh back into shame. Use a large handled screw driver not a precision one.
God no, never do this, the mesh is almost never screwed on unless you're talking about a handheld dynamic mic, when you're talking about USB or studio mics it is almost never screwed on.
@rice guru
https://linustechtips.com/topic/1240378-deformed-mic-mesh/#findComment-13986908
You linked the way to dismantle the microphone. Its held in with 4 screws. You remove screws by screwing.
My point still stands that the base of a rounded screwdriver handle. Possible the one you use to dismantle this microphone is common practice to reshape the mesh.
https://linustechtips.com/topic/1240378-deformed-mic-mesh/#findComment-13989341
