I got this build together 2 years ago - every time I am running any games or GPU/CPU intensive software my computer will freeze. This freezing issue happens randomly, there is no set amount of time before it happens and no set resource usage. Quite frankly I have never been able to max out my resources on this computer. The only solution i've found is a hard reset.
I initially thought it was a hardware problem so I went ahead and replaced every part except the graphics card through warranty to brand new parts, after arguing with support for hours to get that arranged. For the GPU's, I swapped them out with my old 980 TI to test if the issue persists and it does.
I have been looking for a solution for this for 2 years now - Manufacturer support has failed to help me diagnose and fix the issue and at this point I am left with 2 options: getting help from someone who knows more about this than me or, simply put together a new build which is something I really don't want to do.
I have a very powerful computer that cost me a lot that I have yet to fully enjoy, so I am hoping that you would take the time and help me fix this issue.
Computer Specs:
- Intel Core i9 7900X
- Asus ROG Rampage VI Extreme
- 4x DDR4 G. Skill F4-3600C17 16GB
- 2x NVIDIA GTX 1080 TI
- 2x Samsung 960 EVO NVME
- 2x WD HDD
- Corsair 1500W PW
- 6x Corsair LL120 Fans
- Corsair Hydro Series H100i
- Lian Li PC-O11 WGX Case
The plan with this computer is to water cool it with a custom loop, but seeing how unstable it's behaved I decided to put off the water cooling process until I get that fixed. I am currently running on air cooling with a CPU AIO.
I recorded the temperature at the time of the freeze to make sure its not a heating issue and these were the results.
I would really appreciate any help on this, as I am currently completely lost and have no clue what to do to correct this issue.
[EDIT] Computer is not overclocked or anything ... I also tried running with both XMP on and off the results are the same. As for the freeze its not just a game or a software freeze the entire computer freezes and nothing is responsive.
https://linustechtips.com/topic/1240359-major-computer-freezing-issues/
can be anything, go check the event viewer to see any anomalies.
There are more parts that can overheat, like the SSDs, do you really have 4 drives inside the PC? The print screen has all the interesting parts missing, collapsed even.
Maybe you are just maxing out what your motherboard can handle.
Quote
  • ROG DIMM.2: Dual M.2 expansion card allows use of fans to prevent throttling
the SSDs were running at around 70c I didn't catch it in this screenshot but I did on another test I will run another one and take a screen shot for you..
also yes I have 2 HDDs in the back compartment
1 M.2 under the graphics card in a little compartment. and the other M.2 is installed on the expansion card.
11 hours ago, RageTester said:
That is rather toasty, no heatsinks on them, right?
But heat will only throttle your SSD, it will not crash it, so there might be another problem.
yeah man, I can't seem to figure out exactly what is wrong. maybe its a voltage / MB thing that I may have to setup I am not too sure
