In planning my personal gaming computer build over the past few months, a couple of Sabrent SSDs have come to my attention (both 2TB drives): a QLC drive for ~$300, and a TLC drive for ~$400. Does the difference in read/write speed justify a $100 price difference between the two?
Some additional details:
- My budget for this build is high, but not infinite
- I'm hoping to buy two NVMe drives, so my question remains the same whether we're discussing a pair of 1TB or 2TB drives
- I'm looking to purchase a Ryzen 4000 series CPU and a new GPU from either team (I've bled green in the past, but given the industry news I've heard as of late I'm keeping my options open) as each releases
https://linustechtips.com/topic/1240235-tlc-vs-qlc-memory-a-100-difference/
What currency is that? Also do you want to use the SSD as a boot drives or just for game installs?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
what drives are those?
budget and what currency is that? a qlc drive is fine if it's not a boot drive but if it is, i would avoid it..
Phone: Pixel 3a (Purple-ish).
Build Log:
American dollars, and I'll be using it for both -- game installs and boot drives, I'll have a disk drive for bulk storage.
$400 for 2TB is way off. You can get an ADATA SX8200 Pro or Silicon Power P34A80 for $220-250 and those are on par with the Sabrent Rocket.
QLC drives are fine for game installs, but they're not ideal for OS installs, so I wouldn't get the Rocket QLC.
From my brief googling:
https://blog.synology.com/tlc-vs-qlc-ssds-what-are-the-differences
"QLC drives are great for their intended purposes, that is, low-cost drives to replace HDDs in read-intensive workloads. While peak performance can rival even high-end TLC-based drives, their performance in steady-state situations leaves a lot to be desired. Unlike with the quick adoption of TLC NAND in both high-end consumer and enterprise drives, unless steady-state QLC performance improves significantly, we don’t see them becoming a TLC replacement anytime soon."
I'd agree with TofuHaroto on this.
This has all been very illuminating -- I've got an Asus ROG X570 Mini-DTX motherboard, and I was told that the expansion card it uses would only allow me to run two drives in RAID, so unless that's incorrect, I would like some more solid numbers.
