1066 is the same as 2133 essentially.
DDR= double data rate.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1239725-i-need-help-with-ram/#findComment-13965269
27 minutes ago, Pevu said:
And i just took out my RAM and there was 2133
Its correct, that 2133 is actually in MT/s (Mega Transfer/second) not in MHz, but RAM manufacturers market it as MHz anyway the actual frequency is half the frequency marked on the module (2133/2) ~ 1066 MHz.
https://linustechtips.com/topic/1239725-i-need-help-with-ram/#findComment-13965352
