I have just recently built a PC (https://au.pcpartpicker.com/list/wDwVMc) and everything seems to be working fine on the technical end. I have a slight problem though. The PC noise seems to be quite noticeable when its idle and nothing is running. I've spent some time listening to it, and it seems like the loudest part is coming from the power supply. The noise isn't mechanical, I'm 80% sure its the PSU fan.
Is my PSU faulty or have I likely done something wrong? I have also seen in reviews that the GPU I have can be quite loud, but I'm relatively confident that it's not contributing to all the noise.
I'd really appreciate the help, even if you link me a resource that you'd think that would be helpful (I cant seem to find any info that is specific to my situation).
Update: a sound recording of the sound is attached (online link: https://voca.ro/4BSk3Z1lK13
New Recording.m4a
Edited by DenverAU
https://linustechtips.com/topic/1239601-loud-psu-after-build/
the noise, high pitched or low pitched? High pitched buzzing from gpu or psu is typically coil whine.
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1239601-loud-psu-after-build/#findComment-13964314
Sounds to me like there could be an obstruction inside (inspect with penlight from rear, don't open, danger shock hazard inside psu) if there's debris attempt to dislodge by turning the psu over and around and any which way, and convince it to fall out the fan area. (it could just be the whoosh of the fan blowing past the components, they too are an obstruction after all)
The high pitched noise sounds like coil whine to me, you could give the psu warm air to suck in while it's at low load to speed up the fan without changing other operational parameters, if the whoosh gets louder but the whine stays the same then it's not the fan. If you put it under a load with sporadic power draw and that high pitch warbles it's definitely coil whine.
desktop
HTPC
https://linustechtips.com/topic/1239601-loud-psu-after-build/#findComment-13966522
