You can change the fan curve in the bios..
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1238878-and-wraith-cooler/#findComment-13959195
2 minutes ago, HenryFan said:
I'm new to PC bulding
You go to the bios and see a custom fan curve for the cooler.
Where that is depends on the uefi's layout usually.
Build Log:
https://linustechtips.com/topic/1238878-and-wraith-cooler/#findComment-13959202
