Super low temps?
Go to solution Solved by Derrk,
those are really good temps.. might want to try squeezing some more performance out of the 9600k
1 minute ago, bmx6454 said:
maybe it can be lowered if you lower the rooms ambient temperature, but those are nice temps.
Just move to canada lol
Kogan 144hz monitor (Overclocked to 165) Ryzen 3 3100, RX 580 Gigabyte Windforce (1450 mhz) 2 x 8GB CL15 DDR4 3133 (Overclocked from 2400) Phanteks P300 white (RGB set to purple), Zarrius Deskpad (I have the yellow one), Razer Deathadder Essential, CK62 wireless (don’t use it wireless)
https://linustechtips.com/topic/1238783-super-low-temps/#findComment-13958528
