USB Drive Problem
Go to solution Solved by WereCatf,
5 minutes ago, FALL1N said:
any helps ?
The drive is dead. This is exactly how USB-sticks typically die.
Heyyy!!
so here is the problem of my USB drive.
when i plug my USB Drive it shows empty storage,
after i try to format my usb drive pops up an error
i have tried to format with CMD using diskpart and some other programs but still same problem.
any helps ? :(
Akinator V2 is here :D
https://linustechtips.com/topic/1238494-usb-drive-problem/
2 minutes ago, FALL1N said:
so there is no way to fix it ? :(
Basically no. I don't think you have important data on the drive since you tried formatting it so just get a new one 8GB drives are quite cheap.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1238494-usb-drive-problem/#findComment-13956234
Well, if it died because a solder-joint came loose -- something also tends to happen with USB-sticks -- reflowing the solder might fix it, but....well, if you knew how to do that, you wouldn't be asking here. I'm not going to recommend a beginner to attempt reflowing.
https://linustechtips.com/topic/1238494-usb-drive-problem/#findComment-13956241
Just now, WereCatf said:
Well, if it died because a solder-join came loose -- something also tends to happen with USB-sticks -- reflowing the solder might fix it, but....well, if you knew how to do that, you wouldn't be asking here. I'm not going to recommend a beginner to attempt reflowing.
no need that, anyways i just ordered a new one. thanks budy!
https://linustechtips.com/topic/1238494-usb-drive-problem/#findComment-13956243
