If you really need something now, a 5700XT will work but you should probably wait 10-15 days after the 3000 series launches and then get a 2080S for *relatively* cheap.
Kogan 144hz monitor (Overclocked to 165) Ryzen 3 3100, RX 580 Gigabyte Windforce (1450 mhz) 2 x 8GB CL15 DDR4 3133 (Overclocked from 2400) Phanteks P300 white (RGB set to purple), Zarrius Deskpad (I have the yellow one), Razer Deathadder Essential, CK62 wireless (don’t use it wireless)
2 hours ago, xujiayi_1256 said:
I want an upgrade to play Flight Sim 2020
Currently nothing will help you play that game. It isn't even slightly optimized.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
According to tom'sHardware, an upgrade to a higher-end graphics card could yield pretty good results even at 1440p. But I agree with you on the optimization part.
