Hey,
so I am having this problem where when ever I play a game wether it Fortnite cod or anything else, either my of just crashes or the game it self crashes. I don’t know what it could be. I have updated all my gpu drivers and have even did a bunch of ddu’s. I also reset my over clocks for my gpu.
here are my specs
Ryzen 5 2400g
asus tuf b450 plus
2 ssd 1 hdd
gtx 1050 SC
corsair vengeance lpx 16 gb 3200 speed
500watt EVGA psu
ill take any help I can get :)
https://linustechtips.com/topic/1237858-pc-keeps-crashing-pls-help/
Try testing your memory with Windows Memory Diagnostic (Win+R, type mdsched.exe into Run).
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
20 minutes ago, GeneralGusher said:
Hey,
here are my specs
Ryzen 5 2400g
asus tuf b450 plus
2 ssd 1 hdd
gtx 1050 SC
500watt EVGA psu
Ok thanks I’ll check and let you know what happens
35 minutes ago, GeneralGusher said:
It said that there are no errors. Could it be something with my gpu?
Maybe, but you're much more likely to see abnormal visual glitches if it's a GPU hardware issue. Have you tried updating your BIOS?
Desktop
Homelab
not yet. Do you know where I can find the newest bios for the ASUS tuf b450 boards?
https://www.asus.com/us/Motherboards/TUF-B450-PLUS-GAMING/HelpDesk_BIOS/
Desktop
Homelab
