I'm attempting to overclock individual cores to see which are my strongest, so I can achieve maximum frequencies on my 4670k.
Run into a problem straight from the start, my cpu won't exceed the lowest multiplier (I think), for example under full load the cpu won't exceed 4.4GHz despite the fact core #1 has a 46x multiplier (other 3 are @ 44x).
Is it possible I'm just getting inaccurate readouts from cpu-z? It shows my multiplier as '8-46', however it will never display anything above 4.4GHz clock speed.
Thanks for any help!
https://linustechtips.com/topic/123773-per-core-overclocking-help-needed/
I had a similar problem in this thread: http://linustechtips.com/main/topic/118003-i7-3930k-per-core-oc-help/?view=findpost&p=1573961
I don't know any clock speed monitoring programs that are accurate that display Per OC. Even Tmonitor doesn't show it.
§ ragedev.net §
