Previously I made a post a couple of months back
 Pretty much I tried fixing my terrible internet speed which was a constant 15-17 down and 3 upload for the past 4 years. Not until two days ago while messing with my routers setting was I able to achieve a huge jump on download and upload
Before: aNLzlpZ.png
After: aJy3SzY.png
With that happening I'm still hopeful to see the upload speed to increase. What could I do either through my computer settings or router settings to see the upload increase more?
-Thanks in advance
https://linustechtips.com/topic/1237172-upload-speed-increase/
Judging by those speeds your probably on Cable Internet (Coax). Thats about right for what most cable providers do. The cable system has less upstream channels than downstream channels. So upload speeds tend to be crap. Most cable providers can do a max of maybe 35-50 Mbps. Most of the time the higher upload rates are for the faster tiers like Gigabit. I have Comcast (Xfinity) I have 200/10 service. I get like 260/12 most of the time.
https://linustechtips.com/topic/1237172-upload-speed-increase/#findComment-13946212
What speeds are you pying for.
If your lucky, you hve a fiber provider in the area, as those normally have much higher uplods.
But if these re the speeds your pying for, your only reall option is to pay for a faster plan from your isp.
https://linustechtips.com/topic/1237172-upload-speed-increase/#findComment-13946241
