overheating maybe??
Solved by Mark Kaine,
I dunno, if you changed your fans and temps got higher after the fact there's definitely something wrong I'd say.
Also those temps, ouch!
Edit: just looked it up, someone please correct me if I'm wrong, but max safe temp for your cpu is ~65C, so your gpu is fine, but the cpu looks sketchy - I wouldn't use the PC right now until someone can confirm those temps are indeed too high or not.
I'd also check the cpu and fan thoroughly, maybe reseat / new paste, maybe something got lose while you changed your case / fans.
