looking for power supply
Go to solution Solved by Guest,
1 minute ago, Alex Ushigome said:
How much does the HX650 cost in Canada, and if its in stock anywhere?
not available
Antec High Current Gamer Gold for around $140 CAD
Fractal Design Ion+ Platinum for around $160 CAD
Edit: Theres also the Toughpower GF1 for $155 CAD
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
Why are you even asking about a model that was discontinued ages ago?
10 minutes ago, truckerlenny1990 said:
ok so im looking for a power supply that is in stock
650w fully modular somewhat of a 80+ rating around 160 canadian. was gonna buy corsair rm650x but is out of stock
What are you powering, that needs 650W? 2080 Ti + high end mainstream?
there are many reasons i want to use a 650 watt power supply. from my knowledge its hard to find a fully modular power supply with less than 650 watts even then its hard. not to mention id be able to stick with about 50% usage for my specs which would be the highest peak efficiency and i know some psu if your under a certain percentage the fan doesnt even turn on. plus maybe i wanna upgrade later.
I'm seeing RM650x in stock at Newegg for $159.99.
RMx, Ion+, G2, G3, Whisper M, Focus Plus, Prime Ultra, Straight Power 11 etc etc etc... These are not recommendations, just PSUs with wattages below 650W that are fully modular.
The efficiency "curve" for a modern high end PSU resembles a line more than a curve. So that reason is just BS. If you want a quiet PSU, get a quiet PSU. The EVGA G3 1000W is louder at 200W than the Formula 450W is at 495W. Despite the max wattage being much much higher.
And you still haven't answered:
27 minutes ago, Alex Ushigome said:
because I didn't know that because Australia always seems to have discontinued stuff for a fair few years after.
Even in Australia, that thing would have been discontinued for several years. Must be a big rock you're living under. Just to make sure you're caught up, Trump became president in the 2016 election, the Notre Dame burned, and the whole world is experiencing a pandemic.
Cooler Master  MWE Gold Reactor Gold  V Gold 2018.//Not bad
EVGA  Supernova B3 post 2019 //Not bad.
Bitfenix  Formula Gold 650W  Whisper 650w // Best Option.
Recommending Formula gold whisper  because hx650 is is not available.. Asumming you have a mid range rig.
Thanking you,
Yours faithfully,
Celeric07
im not the one who recommended the hx650 i was looking originally at the rm650x
my build consists of a intel 10400, 1660 ti, 16 gb ram 1tb nvme drive asus tuf b460 plus motherboard
and i know i could easily get away with a quality 450 watt psu i couldnt find any that were fully modular nvm i found some guess i didnt look hard.
Just now, Alex Ushigome said:
I bought a HX750 like a year or 2 ago, I checked now and they've been marked as Discontinued, but not for long.
What's this i hear about a pandemic?
The HX Platinum is still most definitely a thing, and it starts at 750W. The 650W versions of older PSU series named "HX" are not. Dammit Corsair, and their recycling of product names.... TX, RM, HX, AX...
A Mexican beer, I think
Corona Extra doos 4x6x0,355L | De Klok Dranken - Drankengroothandel
I was under the impression that it was Spanish
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
There's always an HX that's current.  They just keep getting revised, making the previous version "discontinued".
The current one is the fourth generation:  http://www.jongerow.com/Corsair_PSU_hierarchy/index.html
