I have had my rig for about 2 years and decided to upgrade my cpu from a i5 7400 to an i5 9600kf, after i installed it my pc wouldn't turn on no matter what i tried, so i bought a new 600w psu from cooler master.
still nothing, tried jumpstarting again, nothing. if i unplug just the 24 pin from motherboard and use the paper clip test the pcu powers on and the fan spins, however when connected to my motherboard the motherboard lights startup and the PWR LED is green however it still doesn't work.
please could someone assist me.
Thx
https://linustechtips.com/topic/1236691-pc-wont-power-on/
Which motherboard is it?
Chipsets work for specific CPU series. Maybe your chipset is too old to support the 9600.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1236691-pc-wont-power-on/#findComment-13942225
2 minutes ago, Wulfyu said:
it is an Asus prime z270-a
I dont think z270 supports the 9600. You can google the chipset to see compatible products.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
https://linustechtips.com/topic/1236691-pc-wont-power-on/#findComment-13942253
You need a motherboard with 300 chipset.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
https://linustechtips.com/topic/1236691-pc-wont-power-on/#findComment-13942257
