So I have a problem I moved my pc to my sisters house and it won’t put out any video I tryed 3 different hdmi cables and Reset the gpu and tryed 2 monitors but nouthin works it’s not the tv cuz the Nintendo switch works with the tv and cables Also I have a rx 570 if that matters it worked fine this morning then I had to shut down to unplug it I even have a oculus rift s and though the hdmi port broke so I used the display port on the headset and still nouthin Please help guys
https://linustechtips.com/topic/1236221-plz-help/
Also I just tryed a different slot and nouthin
https://linustechtips.com/topic/1236221-plz-help/#findComment-13938144
Specs of the PC? If the CPU has integrated graphics try using that instead of the GPU and see if you get video out. You can try clearing the CMOS on the motherboard and see if that fixes the GPU problem, but if that doesn't work you're likely dealing with a dead GPU. Try testing the PC with a different GPU if possible.
If the GPU is dead, it's likely that something touched it or messed with it while you were moving the PC which shorted it out.
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
https://linustechtips.com/topic/1236221-plz-help/#findComment-13938146
It’s a ASUS x570 prime pro with a ryzen 9 3900x and 32 gigs ddr4 and rx570 and 650 watt Corsair psu
https://linustechtips.com/topic/1236221-plz-help/#findComment-13938153
Yeah, so no integrated graphics... First thing I'd do is try clearing the CMOS and see if that happens to fix anything. Aside from that, there's not much you can do besides trying a different graphics card. You can't exactly fiddle around with your settings if you don't have any video out...
Out of curiosity, is the PC even booting normally? Often when you have a dead GPU the PC will refuse to even turn on when the GPU is inserted.
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
https://linustechtips.com/topic/1236221-plz-help/#findComment-13938162
Yah all the lights everywhere come on and the lil speaker only dose 1 beep which is normal
https://linustechtips.com/topic/1236221-plz-help/#findComment-13938168
Interesting. That doesn't mean the GPU isn't messed up, but it could be fine. First thing I'd do is try clearing CMOS. Your motherboard may have a CMOS clear jumper you can use, but if it doesn't, or you don't know where it is, you can just take out the CMOS battery for a few minutes (make sure to unplug your PSU before taking it out, and hold down the power button on your case for around 30 seconds while it's out to ensure you drain all the power from the system). If that doesn't work, maybe just check to ensure all your cables are properly connected everywhere? It's possible something came loose inside the PC while you were moving the it? Aside from checking those things there's not much else you can do besides swapping out parts and seeing what's causing the problem (the GPU is the most logical place to start).
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
https://linustechtips.com/topic/1236221-plz-help/#findComment-13938179
Man U r a life saver I found cmos jumper and it worked right off the start had to configure bios a lil bit but then it booted in to windows thanks u sooo much for ur help u r what’s gods r made of
https://linustechtips.com/topic/1236221-plz-help/#findComment-13938304
No problem. Glad it worked! Who knows what messed it up in the first place, but clearing the CMOS is always a good place to start when you have a problem like that.
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
https://linustechtips.com/topic/1236221-plz-help/#findComment-13938315
