Air Cooling Setup
Go to solution Solved by Stahlmann,
2 Front intakes
1 Top exhaust at the rear slot
1 Back exhaust
I prefer to have 1 more intake fan than exhaust, because of the positive pressure you'll have slightly less dust buildup, so if you only have 3 fans leave out the top one.
Hi,
I'm almost done with my new build. I'm out of $ and I only managed to get 3 120mm fans. In the meantime, what's the best way to set them up? Should I go for two intake and one exhaust?
My CPU fan is facing the side panel (stock wraith stealth). My case has two slots in front, two on top and one at the back.
All help is very much appreciated
https://linustechtips.com/topic/1236136-air-cooling-setup/
I would go 2 front intakes and 1 top / back exhaust.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/1236136-air-cooling-setup/#findComment-13937588
2 minutes ago, Koeru said:
Hi,
Mine are setup as 2 intake 1 exhaust but if you don't have a dust filter on your case then use 2 exhaust 1 intake.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1236136-air-cooling-setup/#findComment-13937591
2 Front intakes
1 Back exhaust
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1236136-air-cooling-setup/#findComment-13937663
1 hour ago, Koeru said:
The front and top of the case has dust filters. It's only the back which has bare holes in it.
2 front intakes and 1 rear exhaust.
Desktop :
Laptop :
https://linustechtips.com/topic/1236136-air-cooling-setup/#findComment-13937709
Depends what your case and CPU cooler are. Also 3 fans is well enough for basic cooling. Usually people have more for 3 reasons. 1) They have AIO, 2) They go for looks, 3) They for some reason want to fill every hole.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1236136-air-cooling-setup/#findComment-13942438
