I recently upgraded from my 4790K / Maximus VII setup to a new Ryzen setup due to the 4790K seemingly having some issues with my 2400 MHz RAM. I was considering using the 4790K setup as an upgrade for my Plex server, but in doing some further testing / benchmarking I noticed that when the system is under load, there is a huge temperature spread across the four cores. I've included the picture I took of the temps and voltages right before a blue screen due to a watchdog error. This was while running a Cinebench benchmark. I tried a new thermal paste application and even a different cooler (from an Corsair H100I to a Cooler Master T2), but I got basically identical results both times. I had hyper-threading off while using this setup for my gaming rig, but I reset the BIOS (re-enabling hyper-threading in the process) in between setups. Turning off hyper-threading means the max temp peaks around 80, with the lowest core around 65, and there is no blue screen. The voltages in that case are all even at 1.246ish.
This is mostly just a curiosity since my Plex setup is already more than adequate for my usage, but I'm totally stumped by this one. Any ideas?
https://linustechtips.com/topic/1235657-temperature-spread-issue-on-4790k/
Just now, ShrimpBrime said:
It's running way too hot.
Is the cooler securely mounted? It's not loose or something?
H100 should cool that chip at stock, something seems wrong here.
Yeah that's what I thought too. I re-mounted it and even tried another cooler, but I got the same results.
if core temps are way different, it's probably the TIM under the IHS
4790k is old, so i wouldnt be surprised if it's gone bad
-sigh- feeling like I'm being too negative lately
Makes sense. I had wondered that, but wasn't sure if that was a thing that could actually happen.
Kind of looks like a bad sensor or two, I really cant imagine different parts of the package being that different.
Daily Driver (Lenovo Y700 Laptop)
Manjaro Linux  ||||  Intel Core i7-6700HQ  ||||  16GB DDR4-2666    ||||   GeForce GTX 960m
250GB Samsung 970 Evo | 500GB Samung 840 Evo
Windows Gaming PC
Windows 10 Pro  |||   Intel Core i7-10700k  |||   32GB DDR4-3600  |||   GeForce GTX 1660 SUPER  |||   MSI z490 A-Pro  |||   EVGA Supernova G2 650w 80+ Gold
120GB SSD | 1TB WD Blue 7200RPM
Bedroom HTPC and Emulation Box
Manjaro Linux  ||||   Intel Xeon E3-1231v3  ||||   8GB DDR3-1333  |||  Radeon RX 460   |||  Asus B85M-G
120GB SSD
Living Room HTPC - Optiplex 790 SFF
Manjaro Linux  |||  Intel Core i5-2400  |||  8GB DDR3-1333  |||  Radeon HD 5450
120GB SSD
Dont delid if an upgrade isnt in your budget.
Windows Gaming PC
120GB SSD
120GB SSD
it most certainly is a thing
^ this, if you're not keen on upgrading, dont touch it
it is bad for the cpu to run that hot, but it's more risky to delid it unless you have proper tools to do it
One thing is for sure, blue screens from overheating is gonna kill the OS first, then take out the cpu later.
Watch a bunch of tutorials. Super easy to delid that chip. The only tool you need is a razor blade. Some people would do them in a vice. That's where the die mate tool idea came from probably.
Need any pointers, feel free to ask. I've done a couple of chips here and there. Mostly soldered ones though....
Yeah, luckily I already upgraded my main rig, and my Plex server is still good with the hardware it has, so I might try delidding it, especially since I'm sure it's not worth anything as it sits.
Good to know. I'll look into it some and try it. Worst comes to worse, it's already close to dead as it is lol. I appreciate the offer for help, I'll see what I can find and let you know if I need any pointers. Also I was trying all of this on a throwaway Windows install, so no worries there.
