I just turned on my pc and no audio devices pop up. Such as my headset or monitor. When I click on the sound menu it opens the troubleshooter and says it can’t fix the problem. I opened device manager and there are no drivers for audio installed. I tried installing the drivers and it just shows the devices are unplugged. I even reinstalled my gpu driver because the NVIDIA audio driver isn’t installed. I then did a system restore to a point I know the drivers were installed and the audio worked but it did t fix it. I really need to fix this. Any help is great. TIA
https://linustechtips.com/topic/1235603-no-audio-devices-available/
which audio device? from the hdmi or your speakers?
You may wanna install the audio drivers that came with your motherboard.
Both my monitor’s built in speakers and my headset. I tried and windows just uninstalls them.
I don't see why you can use either.
What motherboard?
https://www.realtek.cz/download-ALC887-sound-driver-for-Windows10-64bit.html
download and install the drivers, next you will need to plug the speaker to the audio jack on the back.
make sure you select realtek high defenition audio on your sound output.
when i try to run the exe it shows that it cant run on my pc
