I have noticed using MSI afterburner that my CPU(i7-4790k) will reach high max temperatures when playing certain games particularly in Modern Warfare(2019). While it averages in temperatures in the low 70s degrees Celsius it will reach max temperatures in the high 90s and today I noticed it maxed at 100 degrees. My cooler is a Hyper 212 LED(Newegg link below) and I haven't *noticed* my CPU ever thermal throttle with it staying at a constant 4.4 GHz, and I have not  done any overclocking except for enabling XMP for my memory having it run at 2400 MHz.  I have been running this system for at least 2 years so the problem would not be related to me just recently mounting it wrong although I am not saying that the CPU cooler is necessarily mounted 100% correctly. Should I be concerned by this or do anything or is this just normal?
Cooler Newegg link
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/
Wait so was that 100c consistent? Or just a spike?
If it's consistently at 70ish c then it's fine, but just to be safe re seat the cooler and re apply thermal paste and check.
Also use something like cinebench and check temps.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13931796
4 minutes ago, Hackerman25 said:
I would just reseat the cooler and see the temps. When was the last time you changed the thermal paste?
The most recent time I changed thermal paste would have been in August of 2018 when I build the system, so 2 years ago.
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13931817
It would have been a spike, it is consistently closer to low 70s. I will maybe try cinebench but I have never done that before.
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13931823
Try a cinebench run and check for temps spikes.
But as I said just to be safe,  you could re apply thermal paste and re seat the cooler.
Build Log:
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13931833
My brother has a Non-K 4790 (I understand you said it's not overclocked so maybe just add 1-2 degree for the lack of XMP) and has the same cooler. He never reached over 74°C on Cinebench R20, for reference score 1751, usually on Apex Legends doesn't go over 55°C. From what I remember 4790 is known for having high spots, people would lap it to try to make it flat, on my first application of thermal paste 1 core run 99°C full thermal throttle while others were on high 60°C max. reapplying fixed it since there was a spot that wasn't covered well.
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13931860
@Jenko32 k and non-k CPUs are not equivalent even at stock. The 4790 has a lower TDP and lower stock clocks vs the 4790K.
https://ark.intel.com/content/www/us/en/ark/products/80807/intel-core-i7-4790k-processor-8m-cache-up-to-4-40-ghz.html
https://ark.intel.com/content/www/us/en/ark/products/80806/intel-core-i7-4790-processor-8m-cache-up-to-4-00-ghz.html
The difference is greater than "1-2 degrees"
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13931873
Ok, thank you for those temps, although I am not sure how fair it is to compare to the i7-4790K to the non K version because they have different base clocks, turbo clocks, and TDPs.
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13931878
Id check what the voltage is running at.
New tim for the cooler.
The cpu is old and so is the tim under the ihs.
Aside from that, are the cpu fans maxed out while at those temps?
Can you improve case airflow at all or test with the side panel off.
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13931880
was saying that because of the XMP, I totally didn't remember the difference in TDP and clock, thanks
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13931883
This.
And this. For my wife's PC, I breathed new life into my old 4790K by delidding it.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13931898
Running cinebench R20 I got a score of 1945 on the default settings (just downloaded and ran it) and the temps never even reached 90 so no huge spikes in that first run anyway.
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13931905
well you could re seat the cooler and re apply thermal paste and check.
though for the most part if it's not constant, 70c is more than fine..
Build Log:
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13931909
When playing games, heat from your GPU will affect your CPU temps greatly, especially with less than ideal case airflow.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13931911
That might also be part of the problem, I am using a NZXT H440 with 3 120mm intake on the front, 2 120mm exhaust on top, and 1 140mm exhaust on back. While I don't think my 1660 super lets out a ton of heat(It stays pretty much below the 70s if it reaches that) it definitely does let out some and I have done a slight overclock on it. And while I don't think my case has horrible airflow it probably would pale in comparison to something like the Meshify C.
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13931931
@HairlessMonkeyBoy@TofuHaroto@Jenko32@Mick Naughty While going over this stuff I realized that the CPU max of MSI afterburner now says 89 degrees(I haven't restarted my system or close MSI afterburner or anything like that), so I think while looking at the max I may have accidentally looked at the graph below which is CPU usage so of course the max is 100. I'm not sure if this is the case but I doubt the max for temp would have randomly change. Thank you all anyway for your extended help and knowledge into this topic/problem, although it seems I made a massive error. Will try not to miss that before posting on a forum again thanks again and have a great day.
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13932128
No worries. We all enjoy talking about this stuff anyway. 😁
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1235524-cpui7-4790k-temps/#findComment-13932136
