Transmission-CUI: How to queue torrents? Or stop them after download finishes
I'm following this YouTube Guide: https://youtu.be/wZY6xTmovuc?t=94 to download Torrents using https://colab.research.google.com via Transmission-CUIBut if you watch the video for even 10 seconds, you'll know that there are no settings, just put commands and run the block.
So, if I set the 2 commands to download 2 torrents, the first one keeps seeding and second one doesn't even start. So, either I need to stop them after they finish downloading, or reduce the seeding time to 0.
Please, just watch the video for a few seconds to understand my problem.
I'm using these commands like so, to make them queue up, which is not working:
!transmission-cli -D -g "/Shared drives/config" -w "/Shared drives/torrent" magnet:...link1
!transmission-cli -D -g "/Shared drives/config" -w "/Shared drives/torrent" magnet:...link2
!transmission-cli -D -g "/Shared drives/config" -w "/Shared drives/torrent" magnet:...link3
because the first line doesn't finish executing as it keeps seeding
I have an idea of using the -f command, which is used to run a script after torrent finishes, but how do write a script to stop torrent, and what language?
Thanks. :)
Thanks. :)
Im not sure if you have something specific in mind, but transmission qt client has a GUI version, you can queue them pretty easily that way. I have no idea if there are commands for that though.
Daily Driver (Lenovo Y700 Laptop)
Manjaro Linux  ||||  Intel Core i7-6700HQ  ||||  16GB DDR4-2666    ||||   GeForce GTX 960m
250GB Samsung 970 Evo | 500GB Samung 840 Evo
Windows Gaming PC
Windows 10 Pro  |||   Intel Core i7-10700k  |||   32GB DDR4-3600  |||   GeForce GTX 1660 SUPER  |||   MSI z490 A-Pro  |||   EVGA Supernova G2 650w 80+ Gold
120GB SSD | 1TB WD Blue 7200RPM
Bedroom HTPC and Emulation Box
Manjaro Linux  ||||   Intel Xeon E3-1231v3  ||||   8GB DDR3-1333  |||  Radeon RX 460   |||  Asus B85M-G
120GB SSD
Living Room HTPC - Optiplex 790 SFF
Manjaro Linux  |||  Intel Core i5-2400  |||  8GB DDR3-1333  |||  Radeon HD 5450
120GB SSD
https://colab.research.google.com/ only allows commands, how do I use GUI?
Looks like you can set multiple torrents to download at once, but from reading the user guide it doesnt look like you can queue them to download in succession, which is what I think you want.
https://cli-ck.io/transmission-cli-user-guide/
Im pretty sure lots of other terminal torrent clients exist, you might have a look at them.
Windows Gaming PC
120GB SSD
120GB SSD
I see but it works a bit differently on the website, if you could take a look on the video that would be great!
In your command above you have
magnet:...link3
The URL for downloading the torrent would be the magnet link
You could look at ktorrent if you need a GUI based torrent client and if you don't want it to keep seeding after its done, then just disable it.
*** Thread cleaned ***
From off topic discussion.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
