I just recently build my first tower which one went well with the whole performance and such. However, I been running some issue with the ARGB lighting. I have a MSI B450 Tomahawk motherboard and the case that I built it in is a Coole Masterbox TD500 with ARGB lighting at the front. The cables that dedicated for the case fan power works fine, but the cable for the ARGB doesn't fit for the RGB slots for the motherboard. I have pictures connected to this to make it easier to understand. Do I need a RGB controller or is there a slot that I'm missing for this?
https://linustechtips.com/topic/1234939-argb-lighting-issue/
that mb only has 12v 4pin rgb and not a 3 pin 5v argb header so you will need some sort of argb controller
https://linustechtips.com/topic/1234939-argb-lighting-issue/#findComment-13933592
