Budget (including currency): 1000 USD
Country: us
Games, programs or workloads that it will be used for: 720-1080p gaming on destiny 2 and warzone
Other details Already bought all peripherals and just want to see if my build would be sufficient for gaming on medium setting at 60+ fps. Also would like to know if the cpu I’m getting would bottleneck my gpu.
https://linustechtips.com/topic/1234597-first-pc-build/
how much do you have left for the build itself?
https://linustechtips.com/topic/1234597-first-pc-build/#findComment-13924699
8 minutes ago, MrPerson said:
Save the 100 Dollars on ^ and bump your CPU up to a R5 3600 or wait for ZEN 3.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1234597-first-pc-build/#findComment-13924707
10 minutes ago, MrPerson said:
Please for the love of god add an ssd.
Desktop :
Laptop :
https://linustechtips.com/topic/1234597-first-pc-build/#findComment-13924711
Or..
If you really need the extra drive.
But the first build is technically better and you could always add a drive later down the line.
Though I recommend waiting for zen 3 and ampere and big Navi.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1234597-first-pc-build/#findComment-13924713
for your budget you can get this
1. fit in an actual CPU
2. got you a ssd
3. faster GPU
4. case has better airflow
5. better PSU for the price
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1234597-first-pc-build/#findComment-13924715
4 minutes ago, TofuHaroto said:
-snip-
dont forget that OP needs a monitor :D
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/1234597-first-pc-build/#findComment-13924722
ah i did not even notice that lol.
or you could go over budget a bit and get a b550 a pro.
or wait for zen 3 and ampere and big navi.
Build Log:
https://linustechtips.com/topic/1234597-first-pc-build/#findComment-13924726
Buy a Windows 10 Key for a lot cheaper of a different site. That 3200g is meant for sub $400 builds so you should not use that in a build of this price
https://linustechtips.com/topic/1234597-first-pc-build/#findComment-13925460
