A good, noise-cancelling headphone?
Solved by VeganJoy,
41 minutes ago, Shadowdude said:Thank you for the suggestions.
So you wouldn't recommend the Sennheiser one? I guess I could save up a little more to get one of these, but I want to know if they'd make a huge difference in my case.
i dont know much about the closed back senns but they should certainly be solid choices. my game headphones are a sennheiser game one for the integrated mic, and it sounds fine. my main headphones are the 6XX and they rock, couldnt recommend them more. open back though, but if you dont use your pc next to a construction site then theyre fine
