Hey guys , I'm building a pc for a friend of mine . Here's what I came up with , is it good ?
CPU : Core i3 3220
Mobo : Asus P8B75-M LX Plus
RAM : Kingston DDR3 4GB
HDD: WD Blue 1TB
PSU : Corsair VS550
GPU : Leadtek GT 630 4GB
Would it be better if I were to substitute the Core i3 3220 and GT 630 for a AMD A10 5800K ?
Its just for normal use . Watching movies , not really into gaming .
https://linustechtips.com/topic/12340-build-for-normal-use/
Agree. Just get 8GB when you're at it. He can have more tabs open at once, I guess. An A10 might not be a bad idea either.
Current build: Antec P180, Asus P8Z68 Pro, Intel i5-2500k, Asus GTX 570 2GB, Patriot 16GB 1600MHz, Corsair HX 650W.
New build: http://linustechtips.com/main/topic/11270-video-editing-workstation-build/
https://linustechtips.com/topic/12340-build-for-normal-use/#findComment-131672
A system like that would use no more than 250w.
I searched up your build thus far.
This should be about the same price. http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=30489248
https://linustechtips.com/topic/12340-build-for-normal-use/#findComment-137064
I think the A10 would be probably your best choice if your not into intense gaming.
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/12340-build-for-normal-use/#findComment-137283
For media consumption you wouldn't miss the performance difference.
And I agree with the 8GB of RAM; my system is consistently above 4GB of RAM usage (usually idles around 4.1GB) with just a browser and skype open, no heavy applications at all.
https://linustechtips.com/topic/12340-build-for-normal-use/#findComment-140273
