1 minute ago, Hydoxuos said:
I had a question...
I want to build a gaming pc for around 900 euro's (Netherlands) and I was wondering if I should go for the B550m aorus pro or the B550 aorus pro, because the B550m will save me around 50 euros, but will it have an impact on the performance?
As long as you don't need the extra expansion slots or features the ATX version offers, you'll get the same performance out of a mATX board.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
https://linustechtips.com/topic/1233668-atx-or-micro-atx/#findComment-13916392
5 minutes ago, Hydoxuos said:
I had a question...
Generally micro atx only gives up pcie expansion slots and is a great way to save money.
I would suggest looking at the MSI B550 Tomahawk or Mortar.
If you want a cheap board thats still excellent for nearly all systems, I would suggest the MSI B550 pro vdh, ASRock B550m Pro 4, MSI B550 Bazooka or MSI B550 A pro
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1233668-atx-or-micro-atx/#findComment-13916401
what are you powering? because these are two different boards (at least in terms of the vrm). but the matx should handle an 8 core and even a 12 core just fine.
budget for a board and what are you powering?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1233668-atx-or-micro-atx/#findComment-13916409
Do you mean CPU and GPU? If so I'm using the Ryzen 5 3600 with the Sapphire Pulse RX 5600 XT
https://linustechtips.com/topic/1233668-atx-or-micro-atx/#findComment-13916425
just the cpu but..
Ryzen 5 3600
yea, both will power it just fine.
as for b550 as a whole, the aorus pro is great, the matx is worse but will power a 6 core just fine, also consider the mortar and the a pro which are good.
Build Log:
https://linustechtips.com/topic/1233668-atx-or-micro-atx/#findComment-13916433
4 minutes ago, TofuHaroto said:
just the cpu but..
Thank you so much!
What do you mean with "just fine"? Will it run OK or great? (if you understand what I'm saying)
https://linustechtips.com/topic/1233668-atx-or-micro-atx/#findComment-13916471
i mean the board wont have a problem with powering the cpu.
Build Log:
https://linustechtips.com/topic/1233668-atx-or-micro-atx/#findComment-13916483
