can someone help me out...should adding extra 8gb ram would be good or should i get 1060 gpu first(my priority is more fps as i use it only for gaming)
my specs
i5 4460,
8gb ddr3 1600mhz ram,
gigabyte-z97 ud3h bk,
2tb hdd,
zotac 1050ti graphic card
corsair cx600 psu
should i add 500gb nvme ssd(even though mobo only support sata 3 not nvme) ?? my hdd is always 100% and avg. response time goes upto 277ms....is hdd bottlenecking
I know the cpu is really old and i am looking to change minimal things before getting a new rig so help me out
https://linustechtips.com/topic/1233644-what-should-i-upgrade-first/
SSD! But if your motherboard doesn't support nvme, you should get a sata one, as pcie one wont work.
Otherwise save your money for a new rig, your current rig is pretty much maxed out for what it is, i wouldnt upgrade any component in it anymore.
The jump from 1050ti to 1060? Not that big.
8gb more ram? Not that useful for that caliber of a rig, just don't open chrome while gaming and 8 is plenty.
I only see your reply if you @ me.
budget?
definitely a ssd
also i'd change the PSU first before putting new things in tbh.
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
my specs
i5 4460,
2tb hdd,
corsair cx600 psu
Get an ssd and maybe (big maybe) a new gpu when the new ones launch. Then save for a new rig entirely. I would stop after getting a ssd and just save for a new rig.
my specs
i5 4460,
2tb hdd,
corsair cx600 psu
I would first suggest getting an SSD for your OS and some frequently used programs. A 240GB SATA drive for about $30 will do nicely.
After that, you could upgrade to 16gb, and maybe an rx580 or 570 (could probably sell the 1050ti and buy a used 570 for the same price as nvidia card often hold their value better, even though the 1050ti is worse), however, I would suggest just saving up for a full new system ( you can keep your storage of course)
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
