IPS Monitor backlight bleed
18 minutes ago, prasanth_1991 said:
Hard for me to say. the picture looks "bright" I guess it depends if you are annoyed by the glow and it interfeers with your work/entertainment. If yes, then ask for a replacement. But remember, you might get another monitor with more bleed or one with less.. it is like the lottery, atleast that is my experience.
I do think that it is alot more than I had on mine.
If you search on the issue here at LTT, then you will notice people with much more BB. If you look at another angle does it go away? or stay? IPS glow often only showcase very little for me and only in the sides (like a... hmm grey/silver fog?) Again my advice is that if it annoys you enough to notice it, then get it replaced. I think you should accept atleast a tiny bit of IPS glow, but not too much backlight bleed.
Google examples of IPS glow and you will understand my point and the differences.
