4 minutes ago, SnowyLynx-_- said:
i know that but i have see tons of benchmarks and they all have way different fps and i just want to get it from someone reliable ig
Thats the point, fortnite is a BR, so you can't really find a matched scenario you will be in. This will give you a general idea of what your going to get.
Disclosure- i don't play fortnite, dar as i know it's a easy game to run, so a GTX 1660 super will be more then enough especelly at low.
https://linustechtips.com/topic/1232971-how-much-fps/#findComment-13910649
but wouldnt the fps be way different if u have a differnet cpu like in the vid its a i9 9900k which s a bit overkill
https://linustechtips.com/topic/1232971-how-much-fps/#findComment-13910658
