3700x Temperature Question
Solved by Haro,
10 hours ago, IAmQuiteFrank said:I am attaching the temps leading up to and including it
only use hwinfo64 or ryzen master to monitor temps for ryzen as others can't do it accurately.
95c is on the higher side of things. try re pasting and re seating the cooler.
also airflow? try opening the side panel for the case, and if there's a huge temp difference, then the case airflow is likely bad.
