Budget (including currency): $900 (Singapore Dollars)
Country: Singapore
Games, programs or workloads that it will be used for: windows 10, autocad, comtech cad and learning manuals
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): AOC FHD 1080p 100hz 3 msec 26.5 inch, Microsoft mambrain keyboard and mouse set,
Upgrading from a Haswell i5 4460 system.
Corsair obsidian 250D - his old case
Ryzen R3 3300x - replacing i5 4460
Msi B450i gaming plus ac motherboard - replacing Asus  z87i - deluxe
G.skill aegis ddr4 3200mhz cl16 16gb - replacing Kingston Hyper X Fury ddr3 2133mh
EVGA RTX 2060 Super 6gb XC - replacing GTX 750Ti
Adata XPG SX8200 nvme 256gb m.2 ssd
Seagate Barracuda 2tb 3.5 inch hdd - his old drive
Optical Blu-ray player/burner - his old system.
Corsair CXM 450W 450w 80+ bronze modular - replacing unknown "time bomb" silver box
Peripherals
CoolerMaster mem-canical keyboard and mouse set - replacing old Microsoft set.
Total $896.70 (Singapore Dollars)
Question : should I spend another $120 get him the R5 3600?
Silent Cerberus - Fractal Design Core500,Ryzen R7 3700x,Scythe Fuma 2,Gigabyte Aorus B550i Pro AX,Crucial Ballistix Elite 3200mhz cl16 16gb,Adata XPG SX8200 nvme 512gb m.2 ssd,Lexar NS100 1tb ssd,Red Dragon RX5700 8gb(bio flashed 5700xt),Corsair SF600 SFX 600w 80+ platinum F-Modular.
Hades - dO.Ob Look into my eyes and see the dark eternal abyss that is your soul and pay for your hidden sins.
Cerberus - the hell hound that guards the gates of hell. Once you enter you'll never escape.
https://linustechtips.com/topic/1230666-itx-budget-system-replacement-build/
it would help if his workload is multi-threaded, given if he can stretch the budget.
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
Depends on what he's doing. For me 4c/8t CPUs are on the edge of being recommendable. If you can fit a 6c/12t processor i'd do it.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
Today the 3300x performs identically to the 3600 because games don't really scale up to 6 cores.
Later on when they probably will, the 3600 will last longer. Is it worth it? I mean it's an upgrade. It'll probably end up saving you some money in the long run.
If you can afford it without cutting corners somewhere, then yes it'll be a nice cpu. If you can't, the 3300x is still nice.
Do you already have this board? What is it priced at? And are you limited to these options?
Phone: Pixel 3a (Purple-ish).
Build Log:
If we go b550 it be over budget, plus the msi board was one of the best b450s
I wasn't going to recommend b550 lol.
Are you limited to these?
Build Log:
He taking a 3D designing/printing class, he isn't gaming much just mostly for the course.
We sold his old cpu, mb, gpu and ram for $210.
