Oc post problems amd ryzen 5
Go to solution Solved by EXTRADODO,
You might need to reset CMOS.
I’m trying to oc my pc using amd software everything is set to auto I set the MHz to the max. Now it won’t post. Is it my power supply that hit its limit? My psu is the kratos m1 550b. I had psu problem in the past with it not posting because it was plugged into a power wing and I fixed it by using a straight wall outlet. Any help is welcome. Thx vlad
https://linustechtips.com/topic/1230216-oc-post-problems-amd-ryzen-5/
Why.
just unplug the battery on your motherboard for a while and turn off the PSU so it all discharges. maybe 5-15 minutes.
You're unliekly to get past 4.5ghz single core, 4.4ghz all core at like 1.375V which is about the max you want to run.
