X570e-gaming, 3800x 4.275ghz, 2080ti, 4X8 g. Skill 3200 16 cjr, 750w ps. My question what's the best way to adjust voltages if the cldo vddpand socvddg don't work on auto when I change to these 3466hz: 16 18 19 trp19 tras36 Trc57-8 (4,6-6,8) tfaw(34,20,36) twtrs4,12 twr(12,10,13,14)scl4(520-550) tcwl16 trtp(10,8,12,13,14) trdwrtwrrd(7,3-8,3-6,3?) tertiary auto those. ODT40-48ohm bus24202024(yields the most variants on boot code error) I'm mostly unsure about using wd19 trp19 ras38 trc 60 tcwl14 and twrrd 4. Why it's not tWR 14 maybe my trcdwr won't allow the heat to dissipate? 1.018 soc 1.38dimm llc3 ultra. Could it be CPU needs less llc than soc?
https://linustechtips.com/topic/1229297-ram-unsure-need-help/
By default the CPU should run at LLC2.
Since you are on lvl3 you have even more voltage droop and by default the SOC should be at around 1.08V to 1.1V, with your lvl3 LLC and SOC votlage you may droop all the way down to 1.0V which may cause you issues.
Remember that CLDO and VDDG may approach but not exceed SOC voltage.
Honestly, I dont know what are you trying to say here. I am assuming that you want to OC your RAM to higher speeds in which case you should first focus on finding the stable settings and not the lowest voltage for what you have right now.
Try all kinds of ODT settings, typicaly between 40-60ohm is what you need but some sticks like less or more. This does not affect performance, only stability.
And I really recommend you to disable ECC when OCing RAM even if you don't have ECC RAM as you will skip the ECC check on boot and it may improve the training of RAM on boot greatly.
should be in
Advanced/AMD CBS/CPU Common Options -> ECC Disabled
https://linustechtips.com/topic/1229297-ram-unsure-need-help/#findComment-13880334
Is soc vdroop hits too low voltage wouldn't it be possible to loosen the tRP or tRCDRD? Since my increased frequency I needed more accessible memory configs. Also I will look at finding a new set of voltages for lvl2 CPU. Soc lvl3 1.05 is too low voltage going with 1.08
https://linustechtips.com/topic/1229297-ram-unsure-need-help/#findComment-13881339
